🎉Community Raffle - Win $25
Join and Win
Create RBE2 on Local Coordinate System
User: "mecjos"
Altair Community Member
Updated by mecjos
Hi everyone. I would like to add rbe2 1d element according to a local coordinate system. How can I do this? Thank you.
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Accepted Answer
    Updated by Altair Forum User
    Hi,
    The  RBE 2 follows the displacement coordinate system of the node. In HyperMesh, from the assign subpanel of the Analysis> >Systems panel select the nodes,  select the coordinate system and set displacement, so that system assigned to the dependent system will move correspondingly.
    User: "mecjos"
    OP
    Updated by mecjos
    Hi,
    Thank you so much for your quick response George. I added a snapshot of my case. I want that  rbe2 rigid link to have dofs of local coordinate system in the snapshot. Is it enough to select center node of rigidlink.?
    Altair Employee
    Hi,
    It is recommended to select both the dependent and independent nodes.
    User: "mecjos"
    OP
    Updated by mecjos
    Ok. Thank you.
