🎉Community Raffle - Win $25
Join and Win
Error 61: No elements found in input data
User: "Arun Shankar"
Altair Community Member
Updated by Arun Shankar
While I try to run a linear static analysis on the model ( https://drive.google.com/file/d/1OqQDTZ1Jy7B-Rekh6HDLXdgLFCLsch0R/view?usp=sharing ) , I'm getting the following error message: "Error 61: No elements found in input data". I ran modelchecker on the model and everything was fine. Could someone please help with this?
1 - 3 of 31
    User: "Viraj_Kulkarni"
    Altair Employee
    Accepted Answer
    Updated by Viraj_Kulkarni
    For some reason the element type for the tets is not CTETRA
    Can you go to 3d panel-->element type
    Make sure you have CTETRA for tetra4, then select all the elements and click update.
    You should be all set. I did try it and it runs successfully with OptiStruct after that.
    OP
    Thank you Viraj. That did the trick.
    User: "Kacper_S"
    Updated by Kacper_S
    I got the same problem but my hypermesh is 2022.3 and I can't do the same actions as showed on picture above. What shoud I do?
