🎉Community Raffle - Win $25
Join and Win
Run analysis using tcl command
Hello,
I used following commands to run analysis but it created only h3d, fem, out, and stat files.
I open out file and it says checking only completed. so there is no analysis process.
#create new folder
md 'implant static analysis$i'
*createstringarray 4 'model=1' 'overwrite=1' 'title=0' 'result=0'
*writeh3dwithoptions 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/Beam$i.h3d' 1 4
*createstringarray 1 'CONNECTORS_SKIP '
*feoutputwithdata 'C:/Program Files/Altair/2017-edu/templates/feoutput/optistruct/optistruct' 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem' 1 0 2 1 1
'C:/Program Files/Altair/2017-edu/hwsolvers/scripts/optistruct.bat' 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem'
Thank you
1 - 12 of 121
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Invoke optistruct.bat with option '-analysis'
    'C:/Program Files/Altair/2017-edu/hwsolvers/scripts/optistruct.bat' 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem' -analysis
    Hello @tinh,
    I added -analysis at the end but it doesnt seem to be working. I find that there are err-5280.out and other files popped out when running.
    Also, is there command for opening graphical interface to monitor the process? that solver view?
    Thanks in advance,
    Alan
    tinhUser: "tinh"
    Updated by tinh
    It is
    exec [hm_info -appinfo SPECIFIEDPATH wish]  [file join [hm_info -appinfo ALTAIR_HOME] hwsolvers scripts hwsolver.tcl] -solver OS -screen 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem'
    Please refer to
    Hello @tinh,
    <?xml version="1.0" encoding="UTF-8"?>2.png.40f03d0aec3c9f4452d6c55764a77c2b.png<?xml version="1.0" encoding="UTF-8"?>3.png.b5bd3d04dae35a42b4c283c4ab4645c5.png
    #create new folder
    *writeh3dwithoptions 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/Beam$i.h3d' 1 2
    Alan
    tinhUser: "tinh"
    Updated by tinh
    Hi,
    That is analysis error, not script error
    So please check what error is
    Hello @tinh,
    It works when i run the analysis manually. Where should i go to check error?
    Alan
    @tinh
    Is this the one you are looking for? I open one of its OUT file. Run Type indicates Check Only
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.3915463a918c619a00d12800b681a4f3.png
    Thank you
    Alan
    tinhUser: "tinh"
    Updated by tinh
    Did you use this command? I said about it on above post
    Hello @tinh,
    I did. And it indicates that check only
    if i ran it manually, it is working as shown below.
    Thank you!
    Alan
    tinhUser: "tinh"
    Updated by tinh
    Hi,
    could you try again with below ? (add -analysis)
    exec [hm_info -appinfo SPECIFIEDPATH wish]  [file join [hm_info -appinfo ALTAIR_HOME] hwsolvers scripts hwsolver.tcl] -solver OS -screen -analysis 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem'
    And, is there any control card in your inputfile that indicate 'check only' ? Please confirm
    Hi @tinh,
    Thank you very much! basically there is a check control card. I deleted it and solver does analysis now.
    One more thing, since it is a for loop. what command is used to close the hwsolver after analysis is finished?
    Regards,
    Alan
    tinhUser: "tinh"
    Updated by tinh
    Hi,
    Maybe, there is no option to let it exit after finished, because it is used for user interaction.
    But you can use tasklist.exe and taskkill.exe of Windows to kill the wish application (a Tk application that's used to display solver informations)
