Altair RISE
Nominate Yourself Now!
Doubts regarding batch meshing
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am using batch mesh to mesh engine head. On each attempt it is reaching 63rd step and then stopping due to segmentation error. It resumes but, do not complete the mesh. With smaller components this method is working fine
1 - 12 of 121
    Altair Employee
    OP
    Hi Alekh,
    Can you delete setting files and try again?
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    try duplicate surfs of comp to a new comp, delete old surfs
    sometimes I see this has effect
    Altair Employee
    OP
    Hi Sir,
     how to clear the older datas in hypermesh like as material, properties and other details in previous session...
    User: "tinh"
    Updated by tinh
    Just right click on materials, properties,... on Model Browser and select 'Delete'
    Altair Employee
    OP
    cool,
    I will start a new model but the older model details shown defaultly... so how to format the older details...
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Do you mean you need to edit the old Material properties?
    If this is the case then right click on the Material and select Card edit.
    Thankyou
    Altair Employee
    OP
    Hi sanjay,
    when I create a new model and create a material like steel but previous model material as shown on window. so how to clear the older model details in the current or new model...
    I hope u understand my word...
    Thanks to reply.
    Can you please share the model so i can better understand your problem.
    Thankyou
    Altair Employee
    OP
    pls see this image...
    Please use the create/edit option to edit the values.
    User: "tinh"
    Updated by tinh
    Oh my god. Just click on position of 'steel'
    User: "tinh"
    Updated by tinh
    If i were you i would click on everything to see affection. Hypermesh is not a bomb, why are you afraid of it?
