🎉Community Raffle - Win $25
Join and Win
Forming 2 Sheets in one Forming Process
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
Hi,
I have a part which consists of two different material layers. I am trying to form those two different sheets in one forming process. They consist of different materials (e.g. steel and aluminum). I modelled the two layers with two shell components. Is there an option to tie this surfaces together as can be done in FEA modelling as a TIE. Because if i don´t they are actually twisting and not sticking together!
Furthermore there was already a discussion about draping of Composites? Is there already a new release out?
best regards and thanks for your help in advance
Thomas
1 - 3 of 31
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Yes it is possible to run HF forming with multiple blanks. there are two options
    1. Run it a layered blank without any contact between the 2 blank
    2. Run it with Type 2 contacts as welded blank..
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Thanks for your answer! can i use the one step radioss solver? or is there a tutorial?
    thanks again
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    This cannot be run in HF one step. This has to be run in the HF incremental profile
