🎉Community Raffle - Win $25
Join and Win
Export the shape of the layers
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
Hi,
This macro
works with V12 of hyperworks ?
If not, is there an update ?
Many thanks,
Sincerely,
Benoit MATTE
1 - 6 of 61
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Benoit,
    Yes, This macro will work seamlessly with 12.0 as well.
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Hi,
    I export my .step from hypermesh with the script. it works correctly.
    I do operation into each step in another software, and I save in .step.
    My question is:
    Is it possible to import again into Hypermesh .step plies in order to do calculation.
    More generally, is possible to import surfaces in .step, apply properties, materials and run calculation ?
    Please don't hesitate to get back to me if you do not understand.
    Many thanks,
    Regards,
    Benoit MATTE
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Yes, you can import the .step (.stp) file in HyperMesh. Go to File, Import-->Geometry to import the file and you can all the operations.
    Note: the imported geometry may need a geometry cleanup before meshing.
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    ok great ! but what do you mean:
    'Note: the imported geometry may need a geometry cleanup before meshing.'
    geometry cleanup ?
    Thanks
    Benoit
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Yes,
    the geometry you imported may have some imperfections, defeautures (not necessarily on all). so you need to remove those stuff for a time efficient and quality mesh.
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    ok, many thanks I will try it !
    Benoit
