🎉Community Raffle - Win $25
Join and Win
How do you mesh this geometry?
Ajay_22186User: "Ajay_22186"
Altair Community Member
Updated by Ajay_22186
 I have tried 2d mesh using hypermesh, its not going well. It's creating a rectangular kind of mesh which is completely incorrect. It's not meshing the entire model, please clear my doubt.
1 - 4 of 41
    Hakan_20716User: "Hakan_20716"
    Updated by unknown
    For element size, you should check the dimensions of the model beforehand. When importing the CAD file, you can use the SCALE function to make the necessary correction.
    OP
    When I meshed using automesh in 2D, it doesn't mesh the entire model. It forms some rectangular mesh inside the tank, not even covering the entire tank. How to solve it?
    Accepted Answer
    Updated by unknown
    The element size must be compatible with the geometry unit system. There are thousands of videos about HyperMesh on YouTube. I suggest you watch videos explaining the basics of HyperMesh.
    OP
    Thanks for explaining and clearing the doubt, it definitely helped me, the meshing is corrected now.
