Why animation is not working in hyperwork CFD 2021 for dam break simulation.
Hello
Experts I am a newbie in the HyperWorks CFD domain. I am trying to simulate the Mudflow experiment that I did in an experiment using the dam-break condition. I follow the dam break tutorial from acusolve help menu and successfully run the simulation. But in post pro0cessing step, I could not able to visualize th result on the wall and desired location. Further, the animation of the simulation does not appear in the post-processing domain. Can someone help me to extract the result?
Here is the snap of post pressing file.
iI want to the output in the form of velocity, depth and impact pressure at pipeline shown by hole along the channel.how to exactly find th output
1 - 1 of
11
Best to review some of the other tutorials as well - for general post-processing guidelines/operations.
Before running, did you specify the frequency of the field output (nodal results)? Solution ribbon > Fields icon. You can specify how frequently (in terms of seconds or time steps) to write the output that can then be visualized in Post.
