Submitted by mikesj on Mon, 04/21/2014 - 17:41
I have an issue with my Concerto trying to get it to boot from flash, I have downloaded the .out files for both the M3 then the C28 with CCS 5.04. SW1.1 - 4 are all off i.e. all pins high, the software works fine with the debugger connected, when I cycle power I also turn SW3.1 off (beforehand) the software will not boot from flash.
the other issue that I have is that the 3 Phase generator which is set at 50hZ runs at 25hZ. Is the due to the debugger settings as I cannot get the board to boot up from flash to test.
