🎉Community Raffle - Win $25
Join and Win
How to read (visualize) the result after running Hyperform Incremental Radioss
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
As the title, I finished running process of Hyperform Incremental Radioss and the result includes some files. So how to read the result? Which file is used to read and by which tool?
Thank you all.
<?xml version="1.0" encoding="UTF-8"?>post-7335-0-27943800-1422262607_thumb.jp
1 - 2 of 21
    Altair Employee
    OP
    Hi ckl51hut
    Run the .rad file(s) using RADIOSS solver manager (or in HyperForm>> Setup>> Run) to complete the computation in RADIOSS which will write-out a <Filename>.H3D file in the working directory.
    You can use the same <filename>.H3D to animate in HyperView.
    Altair Employee
    OP
    hi sir i need to know about how to predict the results upon completion of incremental analysis. I am able to view the different results like % thinning, formability, etc but dont know how to read it and which conclusion should make on that basis.
