🎉Community Raffle - Win $25
Join and Win
API to find surfaces through which a line passes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
 Hi All..
           I have a line (which is basically an extended 'bolt axis line' and I have the bolt head center node). Is there any API to  find all the surface ids through which that line passes (to find the length of the bolt)?
Thanks,
Sudhanva Rao
1 - 4 of 41
    User: "vipin_22401"
    Altair Community Member
    Updated by vipin_22401
    Hi
    Can you try with the intersect option in F8 panel?
    Select line and all surfaces from bolt component. You will get 2 nodes at both ends.
    Then measure distance between these nodes.
    User: "tinh"
    Updated by tinh
    Hi
    I also use that way to classify bolt/nut ^_^/emoticons/default_happy.png' srcset='/emoticons/happy@2x.png 2x' title='^_^' width='20' />
    Altair Employee
    OP
    Hi
    Thanks Vipin...that washelpful..
    Altair Employee
    OP
    Thanks for your time Tinh:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
