Please check the orientation of the 1D element and change the orientation accordingly.
A quick suggestion: before you run the analysis when using bar and beam elements, change the element representation to 3D and check if they are properly oriented or not.
can you check if there any free 1D elements or duplicate 1D elements in your model?
go to >> tool>> check elems>> 1D>> free 1d's
if there are any free 1D elements, please connect them. Delete any duplicate 1D elements
Hi,
Thankyou
