🎉Community Raffle - Win $25
Join and Win
TABFAT Card problem
User: "Yassine Rajoun"
Altair Community Member
Updated by Yassine Rajoun
Hello, I'm working on the fatigue analysis using optistruct and I'm finding a difficulty with the TABFAT card, when I create the table and following the pdf tutorial they instruct on giving TABLE_NUM=2, but the thing is I can't find this TABLE_NUM in the card when I create it and therefore I cant enter the values of Data,y . Btw I'm using the hypermesh 2020 version and also the 2022.
The first picture is my card, and as you can see there is no TABLE_NUM option, while the second picture is the one from pdf tutorial.
1 - 2 of 21
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    in the newer version, you can create the TABFAT curve and then 'edit' it to add as many rows as you need, as a table inside the 'Curve Editor'.
    OP
    But the thing is it's one column tabular data as the pdf states which means there are no X only the Y entries like in the picture I provided earlier.
