ERROR 116: The ratio of the segment radius to length is too large
In am trying to model a wire antenna using FEKO MoM thin wire solver. The wire is defined as multiple wire segments using edit feko. I get the following error message
Segment 1 is too thick (radius/length= 3.94622E+00)
Using postfeko I want to identify the wire segment 1 and modify it s length. Can you please let me know how to identify the a wire segment in postfeko?
