1D and 2D model
JJJ
JJJ Altair Community Member
edited October 2020 in Community Q&A
Hello:
I want to simulate a bus structure, considering not only the structure but also the shell. I have modeled the chassis with 1D elements (beams), and the bodywork with 2D elements (shells). I want to know how I could model the connection between 1D and 2D elements in my model. Thanks in advance.
Answers
  • Rogerio Nakano_21179
    Rogerio Nakano_21179 New Altair Community Member
    edited January 2021
    What Altair Solution are you using to solve your model.
    If Radioss,  a simple way is to use /INTER/TYPE2 to tie the nodes of the beams to the shell.
    Regards
  • BlaiseCole
    BlaiseCole
    Altair Employee
    edited October 2020
    Or you can just make sure the nodes are equivalenced between the shells and the beams... That should work for linear structural solvers.
Welcome!
Welcome!
