🎉Community Raffle - Win $25
Join and Win
active TCL script in two HyperMesh windows
BetaUser: "Beta"
New Altair Community Member
Updated by Beta
Hi,
I am looking for a solution to make TCL scripts active in two HyperMesh windows simultaneously.
Let say I am having two HM windows opening simultaneously, I run a TCL script from a window. This file contains a GUI interface.
I expect that when I perform an action on the TCL GUI ( eg: click a button), the command will be executed in both windows
Any idea will be very appreciated. Thank you!
1 - 6 of 61
    tinhUser: "tinh"
    Updated by tinh
    Hi,
    If HM windows are run on same machine, you just need to load dde package, create dde topics to communicate between the windows
    if HM windows are run on different machines, you need to use socket command.
    another 'trivial' method: after performing some actions on window#1, output those commands to a *.tcl file
    (or clipboard)
    and on window#2, set a timer script that scans for the file or clipboard, detects those commands, then performs them
    BetaUser: "Beta"
    OP
    Updated by Beta
    hi Tinh,
    Thank you for your answer,
    However, I am not clear about dde package. Could you please recommend a source which I can find more information about this?
    Thank you!
    tinhUser: "tinh"
    Updated by tinh
    The usage is listed in Tcl/tk manual. I found it by google (actually everything about tcl I found by google, too)
    BetaUser: "Beta"
    OP
    Updated by Beta
    Thank you, this time I tried to add more TCL keyword and found it.
    PandurangUser: "Pandurang"
    Updated by Pandurang
    Hi,
    (or clipboard)
    dde execute ?-async? service topic data
    here what are the supported topic by HM.
    tinhUser: "tinh"
    Updated by tinh
    Hm does not have default topic.
    You have to create topic by command:
    dde servername -handle ...
    Handling proc will process data passed by dde execute, you have to define this proc, too
