Matrix is singular : No computed solution
Hi, I have designed an axial flux motor with Flux. If I try to simulate it, Flux gives me the following error: ' Matrix is singular : no computed solution The solving process has probably not correctly converged'
1 - 7 of
71
Hi Mihia,
Can you share the log and report file ?
Thanks
Yann
