I cant see nodes and i have problem with xyz coordinates
Sorry, i am new, just today i got this new program.
When i open Hypermesh in the xyz indicator on the bottom left i have no arrows and when i try to rotate the system it seems having some strange type of bug (i upload a video to explain me better).
Secondly when i try to generate nodes i cant see them.
I have seen some past forum about this last point and i already tried to create HW_USE_OPENCL=0 in the environment variable, but nothing seems to be changed.
What it is happening? How can i fix this problems?
Hi,
In the 2019 version, we made changes in the graphic engine. Please test briefly if the environment variable HW_USE_OPENCL changes the behavior.
Please do the following steps:
1. Stop all instances of HyperWorks
2. Set the environment variable to HW_USE_OPENCL=0
3. Start HyperWorks and check if the behavior has changed when clicking Grids.
or
Try updating graphic driver.
Kindly go through the discussion on supported graphics card in the following forum post:
https://community.altair.com/community?id=community_question&sys_id=55d6ccba1b2bd0908017dc61ec4bcbc4
