Defeaturing pin holes
Hello,
While defeaturing , the pin holes are not getting covered, so I just wanted to create a surface to cover the pinholes, and then mesh the whole surface together. Can i do this? Do i have to merge the surfaces together and then mesh it as a whole, or can i select the individual surfaces and mesh? Please help guys.
Hi vishruthdilip
Can you please share your model or post some images for better understanding
Thanks
