🎉Community Raffle - Win $25
Join and Win
Defeaturing pin holes
User: "Viking_d"
Altair Community Member
Updated by Viking_d
Hello,
While defeaturing , the pin holes are not getting covered, so I just wanted to create a surface to cover the pinholes, and then mesh the whole surface together. Can i do this? Do i have to merge the surfaces together and then mesh it as a whole, or can i select the individual surfaces and mesh? Please help guys.
1 - 3 of 31
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi vishruthdilip
    Can you please share your model or post some images for better understanding
    Thanks
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hello ,
    I have attached the images. The green edges are where i have used filler to close the gaps. As far as i have understood , the surfaces are equivalenced. While meshing , should i select all surfaces and mesh together?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.e114eb1db1968f9bd9b62ffe19c03ec2.png
    User: "Pranav Hari"
    Hi vishruthdilip
    You can check the diameter of the pin holes in your model and give a slightly greater diameter to identify your pinholes.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b89faf16ff6e7841bdcceaeefdfa5500.png
    Refer this video on removing pinholes using defeature
    Thanks
