Altair RISE
Nominate Yourself Now!
Is there a way to export a Far Field generated by a math script using Lua?
User: "Israel Lopez"
Altair Community Member
Updated by Israel Lopez
Hello,
I’m trying to export a Far Field that was previously generated by a Far Field Math script.
The manual has this entry:
farFieldData = app.Models[1].Configurations[1].FarFields["FarFields"]  farFieldData:ExportData("temp_farFieldExport",pf.Enums.FarFieldsExportTypeEnum.Directivity,51)
 I was not able to find something similar for the Math Scripts.
My code:
farFieldData = app.MathScripts[1]  farFieldData:ExportData("temp_farFieldExport",pf.Enums.FarFieldsExportTypeEnum.Directivity,51)
 Looks like the method does not exist.
I’m getting the error:
Attempt to call method ‘ExportData’ (a nil value)
Is there a way to export the Far Field?
Of course I can do it directly from PostFEKO, but I’d like to do it in a script.
Thanks
1 - 3 of 31
    User: "Madelé"
    Altair Employee
    Updated by Madelé
    Hello @Israel Lopez
    You should be able to do this with a script by referencing the math script as you did, then first storing the data before exporting.
    farFieldData = app.MathScripts[1] storedData = farFieldData:StoreData() storedData:ExportData("temp_farFieldExport",pf.Enums.FarFieldsExportTypeEnum.Directivity,51) storedData:Delete()
    Kind regards
    Madelé
    OP
    Hello @Israel Lopez
    Kind regards
    Madelé
    Thanks Madelé
    It worked just fine
    User: "Madelé"
    Altair Employee
    Updated by Madelé
    Thanks Madelé
    It worked just fine
    Thanks for the feedback. I'm glad to hear that it worked!
