SPH in RADIOSS
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello guys, I need some advice:
I need to simulate the behavior of a cylinder-shaped fluid mass contained between two plates ,within a hollow cylinder (like illustrated in the figure attached). In particular, I need output data about the pressure field within the fluid due to the application of a huge force/pressure on one plate so that the whole system accelerates within the hollow cylinder at tens of thousands of g's. The other plate reacts to the motion only with its inertia, so that after a transient phase there is a steady state condition in which the distance between the two plates is fixed, for given initial data.
It's my first contact with radioss or with any explicit solvers so it's pretty hard to get what I need.
I will also attach a first model (hm file) that I built in Hypermesh. It actually runs with radioss, but with nonsense ETA if compared to the simulations time.
I also have some other question:
-where can I find a list of the control cards which are supported by RADIOSS so that I can understand how they work?
- how do I set a contact between an SPH and a 2D shell mesh? I used a type7 contact but I don't know if it is right.
If anybody could help I would be very grateful. Thanks in advance!
