Error while solving.
Hi all,
I pre-processed a grillage structure in Hypermesh and when I solve in nastran, it tells the following error:
^^^ USER FATAL MESSAGE 9050 (SEKRRS)
^^^ RUN TERMINATED DUE TO EXCESSIVE PIVOT RATIOS IN MATRIX KLL.
^^^ USER ACTION: CONSTRAIN MECHANISMS WITH SPCI OR SUPORTI ENTRIES OR SPECIFY PARAM,BAILOUT,-1 TO CONTINUE THE RUN WITH MECHANISMS.
I understand that it says since it is not properly constrained, it forms a kind of mechanism so the run terminates. While i tried all I could both in Hypermesh and Patran/Nastran, I don't know why I am getting the same error again and again..
I have constrained the degrees of freedom of the structure in the independant node of a RBE2 element. Load application is also through an independant node of RBE2 element.
I solved with even single node constraint and all failed due to the above error. Can anyone help me to solve this error..?
Saravanan, this sounds like a NASTRAN support question to me. [-x
I suggest you use Radioss Bulk instead to figure out your problem.
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
