1 - 2 of
21
- On the toolbar, select physics
- From the physics, select orient wires of coil conductor regions
- Flux open a window. In this window you select the phase and an external terminals
- You get a new window, inside this you select the face that represent the input of the current
Hi,
The electric terminals are created to show the input and output of the current in each phase. To do it:
Hope this will help.
Thanks for your help.
Hi,
