Good morning Can someone help me with a doubt? I'm making a linear motor model following the instructions in the LinearMotor_3D_Case2 example, but I do not know how the terminals shown in the figure are defined. Thanks for the help
The electric terminals are created to show the input and output of the current in each phase. To do it:
Hope this will help.
Hi, The electric terminals are created to show the input and output of the current in each phase. To do it: On the toolbar, select physics From the physics, select orient wires of coil conductor regions Flux open a window. In this window you select the phase and an external terminals You get a new window, inside this you select the face that represent the input of the current Hope this will help.
Thanks for your help.
