Enabling wrap text in TableView cells
Is there a command / option that we can use to enable word wrap in TableView cells. Right now, when a cell has data that is longer than its width, it just shows '...' at the end instead of the actual data when I publish the TableView window to an html file. It shows up correctly when I publish a .ppt but not in an html.
Any help is appreciated.
Thank you.
