Enabling wrap text in TableView cells
Is there a command / option that we can use to enable word wrap in TableView cells. Right now, when a cell has data that is longer than its width, it just shows '...' at the end instead of the actual data when I publish the TableView window to an html file. It shows up correctly when I publish a .ppt but not in an html.
Any help is appreciated.
Thank you.
1 - 4 of
41
I found it, @jcd
it use tk treectrl widget
to enable wrapping for TableView, enter command
foreach widget [winfo children .] { if {[string match .tblview_* $widget]} { catch {$widget.frame.ctl.table element configure etext -wrap word} } }
I found it, @jcd
@tinh : This is brilliant! Exactly what I was looking to achieve. Thank you so much
I don't know how to open TableView,
Could you show me?
