Hi All,
I want to model two cylinder in contact (one is in the other one) for analysing Hertz pressure.
1. What kind of contact must i define ? or fixed contact is enough ?
2. At the Result of analysis, how can i display the Hertz pressure ?
3. Any documentation as a tutorial ?
Thanks in advance...
You can refer two below example from OptiStruct example guide.
OS-E: 0185 Rubber Ring: Crush and Slide Using Self-Contact
OS-E: 0165 Contact Smoothing With Two Concentric Rings
