Difference between BAR & BEAM Element
Hello Team,
I have a doubt regarding the BAR & BEAM Element. What is the difference between these two 1D Elements ?
- https://www.quora.com/What-is-the-difference-between-a-beam-and-a-bar
- http://www.stressebook.com/beam-and-bar-elements/
Dear Students / Participants,
You can refer the below provided chart to understand the difference between BAR & BEAM Element. You can see BAR & BEAM Elements both supports 6 dof's ; but BAR Elements are applicable for Symmetric C/s & BEAM Elements supports unsymmetrical C/s too.
You can watch our YouTube Channel Video for the same topic , where we have tried to explain all these topics.
Theory of FEM -
To know more about, You can refer attached PDF ( Theory of FEM )
Hello,
could you please tell me, what EXACTLY means 'one dimension is much larger than other' in the case of 1D elements? Could you please tell me EXACTLY how many times larger? Does it mean that lattice structure which is represented in OptiStruct is useless?
Hello,
Nothing is EXACT in Numerical Simulation world.
I just wanted some recommendation, something like 'at least...' or 'do this, then do that...'
