🎉Community Raffle - Win $25
Join and Win
Retrive BeamSction ID
User: "brahmadev"
Altair Community Member
Updated by brahmadev
Hello Forum!
How do I retrieve the beam section ID assigned for a bar2 (CBAR) element in NASTRAN profile?
 and for any given beam section ID how to I determine a given ID is 'shell' or 'generic'
Thanks in advance.
Regards,
Brahmadev.
1 - 7 of 71
    User: "Jeffersondhv"
    Updated by Jeffersondhv
    Hello brahmadev,
    It's been a while since I've worked with beam sections or the NASTRAN profile, but I would suggest to you looking into the matrix browser.
    Within the matrix browser you can see the information there is regarding all the properties the elements were assigned.
    From the datanames you can then identify the path for the intended information within the database.
    Hope this helps.
    Best regards
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Brahmadev,
    You can find the config of the element using:
    hm_getvalue elems id=$elemID dataname=config
    This will return a number which is associated with the type of element in this case Bar2 (60)
    To get if it is shell or generic find the beamsect id:
    hm_getvalue beamsects id=$beamId dataname=sectiontype
    This will again return a number which will be associated with the sectiontype.
    Refer datanames help for more info.
    User: "brahmadev"
    OP
    Here I want to retrieve the the beam section ID which has been assigned to a given CBAR element...
    User: "tinh"
    Updated by tinh
    beam section is assigned to property, not bar elem.
    from a bar elem, get its property (dataname: 'collector.propertyid'}
    then from that property id, get beamsection id (attribute name: \$BeamSec)
    User: "brahmadev"
    OP
    property  dataname: 'collector.propertyid'}
    Where do I find the ' attributes name or dataname  '  in help files as in future I may require some other. So, from where should I refer these names ?
    User: "tinh"
    Updated by tinh
    Data names are in hm reference help.
    Attrib names: use hm_attributelist
    User: "brahmadev"
    OP
    Woah thanks a lot tinh . This has helped me a lot.
    Regards,
    Brahmadev.
