Composite Wing Free Size Optimization
Hello guys,
I'm working on my master thesis which is the structural optimization of a rear wing for a race car.
The wing is composed of 2 skins (top and lower) and one structural rib on the middle. All these parts are bonded together.
Here you can see the side view, the three elements of the wing with the standard lay up
Here you can see the view from the Top
And in here you can see the rib.
I've modeled the connection between these elements with are connectors of the rigid type:
Connector as seen from the side.
Connectors as seen from the top.
The wing is constrained on the middle on all 6 DOF:
And on the rest of the top skin, a 400kg load is applied:
I've run the standard analysis and for the general lay up everything seems fine. The deformations, stresses and the failure criteria all sound plausible.
The thing is, when I try to run the first free size optimization a lot of weird things happen:
1 - It takes a LOT of time - for each iteration it takes 30min or more
2 - It starts fine, but then it completely violates my constraints
3 - The % of constraint violation does not match
I think I've followed everything as it is supposed, but I'm not getting any decent results...
Can anybody help me?
Sorry for the long post...
Gonçalo Pimenta
PS - The plies shown above are for the general lay up (each ply with .66mm tchickness). For the analysis, I switched to 2mm. On the standard analysis I get 6mm maximum deformation on the wing and for the optimization my constraint is 6mm maximum displacement.
