copy elements
Hi. I am trying to mesh a model that is symetric. So i did mesh half of model ,then attempted to make a copy of the element to the half left, i used the Reflect command in Tool Panel as the recommendation of one friend, but when i finished, i lost the elements in the first half. could anyone help with that problem? thanks
Yes after using reflect option you should use free edges command to ensure connectivity.
May I ask if I want to copy plenty of the elements in a fixed space increment, is it possible to do in Hypermesh? Thank you.
Hi,
If you are trying to make several instances in a fixed increment use Transformation tool, from Tools menu.
Choose the elements, give the increment, direction and also the number of copies required.
The same operations are shown in the attached video (swf format, opens in GOM player).
Have a look at my pictures: You have to duplicate your selected elements before doing 'reflect'
