How to request CE_FRIC interface TH output? Or: how to request friction energy?
Hello everyone,
what do you have to set in order to request the CE_FRIC output? The documentation is very unclear and only mentions the existence of said output variable. Screenshot from the /TH/INTER doc:
It is mentioned below this table that the ENG_VERS card must be 2021, which is the case. So which interfaces actually support this output request? Is there something else that must be defined? I searched in the solver card TH/INTER but to no avail. For the moment, I'm using a TYPE20 interface but tried the TYPE24 as well, since it's mentioned in the doc, but without any change. Is this only available with QFRIC and TYPE7/TYPE21 interfaces? Which other methods are there to plot/monitor friction energy? Additionally, is there a specific way to monitor the total energy balance or should one just sum all relevant energies?
