Altair RISE
Nominate Yourself Now!
Remap Pressure Loads
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
In the model I am working on, I have several loadcases with different pressure load distributions.
I had to remesh the surface I was working on and now I have a more coarse mesh with different element ids.
How can I use the loads applied in the previous mesh and adapt them to the new mesh?
1 - 2 of 21
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    If you can produce your pressure field under the following format:
    x-coordinate, y-coordinate, z-coordinate, pressure
    so you can do mapping this field to any mesh.
    Altair Employee
    OP
    Hi,
    Actually, I am able to do in that way.
    For example, with the first mesh I had the following pressure loads:
    PLOAD4         1 3210001 0.00079
    PLOAD4         1 3210002 0.00082
    PLOAD4         1 3210003 0.00079
    All loads (positive and negative) are perpendicular to the original mesh.
    I am able to remap those pressures to the new mesh, being the end result the following:
    PLOAD4       101 10000116.4766-4                                        +
    +              0-.283875.8665895.4104112
    PLOAD4       101 10000105.9349-4                                        +
    +              0-0.27855.8736424.3989474
    PLOAD4       101 10000096.0673-4                                        +
    +              0-.283721.8694421.4044413
    The vectors define the orientation of the loads. The problem is that, due to the differences in the mesh, some loads don't stay perpendicular to the elements.
    If I could convert the loads while mantaining the original format, the negative loads would not need the orientation vector to define them, and just the signal at the beginning of the load would be suficient to define.
