🎉Community Raffle - Win $25
Join and Win
What's the criteria for positive and negative of force in API
User: "Raheem Sterling_22160"
Altair Community Member
Updated by Raheem Sterling_22160
Hi
I know the contact.force act on the contact point of particles, and then act on the element1 and element2 is opposite.
In HM model, I saw the equation is image, but in the code, F_n = unitCPVect * -factor, and the F_t is as same as the equation.
For F_n, does it because the unitCPVect = contact.contactPoint - element1.position, and this direction is "-" in the EDEM?
1 - 1 of 11
    User: "Renan"
    Altair Employee
    Updated by Renan
    Hi Raheem,
    The equation you posted is used to calculate the magnitude of the normal force. Since forces are a vector quantity we also have to specify their direction and since the forces on the Hertz-Mindlin model are repulsive, they have to point in the direction such that the particles are separating, so the "-" sign in the equation is there just to make sure that the forces are actually repulsive.
    Best regards,
    Renan
