🎉Community Raffle - Win $25
Join and Win
Hollow Coil in the Non-mesh Coil Option
User: "jerometeoh"
Altair Community Member
Updated by jerometeoh
Good day,
I am wondering it it possible to construct hollow coil when using the non-meshed coil option?
Also, how much different in results between hollow coil and solid coil, assume both have the same diameter in the cross section?
Regards,
Jerome.
1 - 1 of 11
    User: "asoualmi"
    Altair Employee
    Accepted Answer
    Updated by asoualmi
    Hi,
    In the menu non meshed coil of Flux there no option to create a hollow coil. But there is a way to do it. it consists in creating a combination of several non-mesh coil. About the results, if the application it is a motor, this don’t affect really the results. But if it another device, this may be affecting the results.
    Best regards.
