Good day,
I am wondering it it possible to construct hollow coil when using the non-meshed coil option?
Also, how much different in results between hollow coil and solid coil, assume both have the same diameter in the cross section?
Jerome.
In the menu non meshed coil of Flux there no option to create a hollow coil. But there is a way to do it. it consists in creating a combination of several non-mesh coil. About the results, if the application it is a motor, this don’t affect really the results. But if it another device, this may be affecting the results.
Best regards.
