How can I create a indoor database with Winprop API
Hello , I notice that in Winprop API -> Data Structurs exists functions like COORDPOIN,T INDOOR_WALL, INDOOR_WALLS, MATERIAL and so on. I would like to create a indoor database with these functions, but I didn' find an example. Is this possible with C++? Do I need a Cmakelist? An could anyone give me an example?
Hello,
you can fill the mentioned data structures to create an indoor scenario and then use the API fct. WinProp_ConvertWalls to save it in the binary WinProp .idb format which can be loaded in WallMan, please have a look in the API guide for details. Unfortunately there is no such example provided with the installer.
In order to display the indoor database for verification you will need to use the WallMan tool.
Alternatively you might create the indoor scenario using the WallMan GUI or define it using the ASCII .ida format, please see chapter 3.3.4 of the user manual for details about this format.
