🎉Community Raffle - Win $25
Join and Win
How to Obtain S parameters from far field source?
User: "Juan Felipe Caicedo"
Altair Community Member
Updated by Juan Felipe Caicedo
Hello to everyone.
I'm trying to obtain the s parameters from two antena that are copuling, one I set it up as a far field source and the other one as a ideal RX. I do not have their geometries but im trying to obtain their S parameters in order to see the coupling.
Does anyone know if i need to define any extra element to set the s parameters? It's important to say that I don´t have a port due to the lack of geometry.
Should I define one? and to which geometry?
Thanks a lot
1 - 1 of 11
    User: "Shannon_Mistry"
    Altair Employee
    Updated by Shannon_Mistry
    Hi @Juan Felipe Caicedo
    The coupling between 2 equivalent sources can be derived from the received power by the following equation in PostFeko:
    Please refer to example B.3 Antenna Coupling Using an Equivalent Source and Ideal Receiving Antenna from the Feko Example Guide for a step-by-step tutorial.
