🎉Community Raffle - Win $25
Join and Win
select elements of different component enclosed within different component's CAD surfaces through script
User: "ATLURI BHARATH KUMAR"
Altair Community Member
Updated by ATLURI BHARATH KUMAR
I have (mid surface + elements) of CAD in one component and the CAD surfaces in other component. can anyone suggest a code to detect the elements within CAD surfaces with the condition (elements are independent i.e., not on surfaces)
1 - 3 of 31
    User: "AndreasAltmann"
    Updated by AndreasAltmann
    Hello @ATLURI BHARATH KUMAR ,
    I have created a script for our models, which will sort the FE-Components to a Part based if the FE-Mesh is within one solid (of one component) of the Part.
    Procedure:
    Create a list with all components that contains solids
    Create a list with all components that contains mesh
    Loop through all components with the mesh and pick 50 random nodes (to increase speed) from the mesh. Check with every solid, if a certain percentage of nodes are within a solid (command  "set isInSolid [hm_ispointinsidesolid $x $y $z $solidId]"). If there are more then 30% of the nodes part of the solid I will organize the component to the part of the solid.
    This takes quiet long to go through a bigger model, but I haven't found any other way so far.
    BR
    Andreas
    OP
    But here I have only surfaces not solids. Can you help in this scenario
    Haven't tried myself, but I think "hm_getcoordinatesfromnearestsurface" can help you in this case.
    https://help.altair.com/hwdesktop/hwd/topics/reference/hm/hm_getcoordinatesfromnearestsurface.htm
