🎉Community Raffle - Win $25
Join and Win
Force component in particle body force
Hi,
I want to convert the total force of particles in the x-direction into a certain value, and add a value to the total forces in the y and z directions. So I did some changes in PBF as below:
double a=1.0;
results.force.setX(a); //set force in x direction as zero.
results.force.setY(results.force.getY()+a); //set force in y direction as +=a.
results.force.setZ(results.force.getZ()+a); //set force in z direction as +=a.
However, the results were the same for all three cases, with the particles experiencing a constant force of 'a'.
Because the functionality I want to achieve in the x-direction is "=", and the functionality I want to implement in the y and z directions is "+=".
Thanks
1 - 2 of 21
    Hi Raheem,
    Looks like a typo in that lines 3 and 4 should be set and get Y and Z, both currently X:
    results.force.setX(results.force.getX()+a); //set force in y direction as +=a.
    results.force.setX(results.force.getX()+a); //set force in z direction as +=a.
    Otherwise I'd expect that to work ok,.
    Regards
    Stephen
    Hi Raheem,
    Regards
    Stephen
    Sorry, I made a written mistake in the question and revised, it should be:
    double a=1.0;
    results.force.setY(results.force.getX()+a); //set force in y direction as +=a.
    results.force.setZ(results.force.getX()+a); //set force in z direction as +=a.
    But it wasn't right. Then I debug the system line by line as below, it seems like "tmp3" wasn't assgined the value of results.force.getX(). I still can't fixed the problem.
