Problems with DXF import
Hello all,
i've got a problem with flux and the import of some dxf files (created with solidworks). Sometimes the ok button for the import confirmation seems 'inactive' and couldn't be pressed after i selected the desired file.
The file names don't contain any space or backslash..
Thanks for your help!
1 - 2 of
21
Hello,
Can you counter check there is no 'strange' character in the name ? I believe the - sign is not allowed for instance. It is better if the name is short (and also the length of the path since the root part C,D,E,..., as there is a maximum length).
I hope it will help.
