🎉Community Raffle - Win $25
Join and Win
Subcases in Hyperview + export options
Hi everyone,
I have a small question about Hyperview. I am running a size optimization of a tube frame. This exercise can be found in the following link:
https://altairuniversity.com/learning-library/size-optimization-tutorial-of-a-tube-frame/
I have incorporated multiple load cases which are also included in my constraints. So the constraints are applied to every loadstep. When I run the analysis and open hyperview, I can only select one subcase. Does this mean that only this load case is included in the optimization or are the other load cases also included in this results? Because I would like to investigate the stresses in the design for the different load cases. Another question that I have is that I would like to export this result. What are the options for exporting this results? I hope that someone can clarify this for me.
Regards, Mike
1 - 6 of 61
    Hi Mike,
    Are you sure you exported the other loadcases to your input deck (.fem file)? If so the results should be visible in the HyperView session file on seperate pages.
    What exactly do you want to export? You can use the query panel to export element stresses.  image.png.cecedb9c5966e732949dc1e194a0e030.png
    Regards,
    niwi
    Hi Niwi,
    Thanks for your reply. When I perform the optimization according to all the steps, then I am not able to visualize or select the different loadcases in Hyperview. When I just perform a simply analysis without any optimization, then I am able to select the different load cases. But when I perform a size optimization I only see one load case. My question is: are all the load cases  incorporated in the optimization process just as with topology optimization. Or am I doing something wrong?
    <?xml version="1.0" encoding="UTF-8"?>Printscreen.thumb.jpg.5d7a681f4b86c44f98722e5e436ca9fe.jpg
    After the size optimization, I would like to do further analysis in Ansys. I can see the mass and the member sizes in the output file and therefore I can manually load this line model in Ansys and assign a cross section to the different line elements. But I was wondering if there is another method to do this.
    I will attach my tutorial files so that you can have a look.
    Regards,
    mike
    Hi Mike
    Your input deck looks fine and you're using all three subcases.
    Your result folder should include one h3d file for each subcase as well (usually ending on s1.h3d, s2.h3d, and so on). You need to load these, if you want to see the stress results for each specific loadcase. Otherwise you can just import the session file (.mvw) which includes results for each subcase each on a seperate page.
    As for your other question, you can create a file containing the updated property definitions. You need to set the OUTPUT,PROPERTY Card. I'm not familiar with Ansys, so I'm not sure whether that is of any help in your case.
    Regards,
    niwi
    Thanks Niwi,
    I am not able to import the session manually, because the button is grayed out. Maybe this is due to the fact I am using the student version of Optistruct. But I can import the results manually by selecting the separate load cases. So therefore I can visualize the results manually. I will try to use the Output, property card in order to check if this option is useful for the post-processing of the results. Thanks for the feedback.
    Regards, Mike
    Hi Mike,
    I got the same problem here. May you please tell me how to solve this issue ?
    I have different loads. When I run one load at time it is okay but when I run all the loads together, I'm only able to see the results relative to one load
    Thank you
    Hi Mike,
    Thank you
    Michele,
    if we take the example mentioned in this thread, OS will generate three h3d files:
    • Tutorial_tube_frame_s2.h3d
    • Tutorial_tube_frame_s3.h3d
    • Tutorial_tube_frame_s4.h3d
    each one related to the single load case.
    You can:
    1. use the fem deck as input
    2. use the "add multiple results" icon at the right end side of the results entry field
    3. point to all h3d files
    4. load all data and process them as you should be used with HyperView
    Please, see screenshot below for the same.
    Let me know if this can help you further.
    Best regards
    Michele
