Subcases in Hyperview + export options
Hi everyone,
I have a small question about Hyperview. I am running a size optimization of a tube frame. This exercise can be found in the following link:
https://altairuniversity.com/learning-library/size-optimization-tutorial-of-a-tube-frame/
I have incorporated multiple load cases which are also included in my constraints. So the constraints are applied to every loadstep. When I run the analysis and open hyperview, I can only select one subcase. Does this mean that only this load case is included in the optimization or are the other load cases also included in this results? Because I would like to investigate the stresses in the design for the different load cases. Another question that I have is that I would like to export this result. What are the options for exporting this results? I hope that someone can clarify this for me.
Regards, Mike
