Extraction of stress results
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
How to extract the stress from different load subcases for a particular node and export it as a file?
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2016
    Hi Vijay,
    Stress results will be extracted separately for different load cases.
    What is the solver you are using?
    If you are using OptiStruct, you can request to write the stress results in a ASCII file (OPTI)
    the other way is in HyperView, goto Query panel>> Select all elements (or elements of interest)>> click apply>> and click export to have the results in text format.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Prakash,
                    Thanks for your response. The solver is ansys. The query panel is extracting results for the selected load case alone. But I need to extract the results for a particular node for different simulation steps. Is there a way to do it ?. I have observed under Export* in menu bar, there is an option to export the 'contour values from ID-list/picking' . But that option works only for all load steps. Is there a way to find the contour values similarly for all simulation steps?. Thanks in advance
    Regards
    S Vijay
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    If have access to Altair connect :knowledge database : scripts.Please check with proper keyword.See attached screenshot.
    Note:Commercial customer have access.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Rahul,
    Thanks for the response.
    Regards
    S Vijay
Welcome!
Welcome!
