Hi,
I have some models in Simulink.
How do I open those in Activate.
Kindly,Help me with this
Thank you
Hi Lokesh,
for the import of Simulink models, we have a dedicated library called Simport.
You can download the current version of the Simport library for Activate in the connect portal: https://connect.altair.com/CP/downloads.html?suite=HyperWorks
I attached some slides incl. some explanations.
Please, let us know, if this helps!
Best
Christian
Attached also a video that shows how to install and use Simport Library
Liv
Thank you so much for the video and document.
I have some doubts
is it compulsory to give matlab file? coz i have only Simulink file
and also what is that result log file?
i am getting this error
Error: can not open 'C:\Users\lokesk\AppData\Local\Temp\Tempdir_NzrkAy\simport.bat': Permission denied in function execute_command at line number 148 in file simport_import_to_oml.oml
please help me with this
Thanks
It's not compulsory, it's optional. If your model uses functions written in an m-file you can add the file to the import.
The log file reports all messages from the import process. After opening (and closing) projects the path is filled with the temporary project directory. If the associated project has already been closed, the directory doesn't exist any more. Please try to fill in just a name of a log file without any path.
Hi @LOKESH KATARI,
Did you get the import running? While checking the import on my computer I got the same error message. The reason was a mix of versions of Activate and import library. Today I've installed the brand new version 2020 and Simport_V1.4_for_Activate2020 and everything works fine!
Regards
Thank you so much
its working
Lokesh
Hi I am still getting the same error and I installed like you told
can you please help me with this?
oml Error: error when executing 'C:\Users\kbrm\AppData\Local\Temp\Tempdir_dX2Ugm\simport.bat': simport warning: xml deep ast to xml explicit ast: dropping 'Object' implementation section item simport warning:
Hi Lokesh Katari,
The quoted message just contains simport warnings. The error message itself follows later. Please can you post it?
Hey hi
You got a PM
