Altair RISE
Nominate Yourself Now!
Mapping Elements to Surfaces for Symmetric Plies
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello everyone,
I have a question that I don't know if it's possible to solve this way but, here it goes anyway.
The model I'm trying to optimize using Optistruct is a wing loaded with a pressure on its top skin. It has a symmetry plane along the XZ axis. You can see this below:
<?xml version="1.0" encoding="UTF-8"?>base_geometry.thumb.png.cece4cb46df3b4adbce4b537188c3f1a.png
This is the base geometry of the wing imported to Hyperworks through an STP file.
<?xml version="1.0" encoding="UTF-8"?>50051645_symmetryplane.thumb.png.fafe9ffe981c13bad702276ff7defd1d.png
Here, you can see the symmetry plane displayed on CATIA.
__________________________________
The load is a pressure that I apply on the surfaces I want and then I map them to the nodes corresponding to the surfaces using BC -> Loads on Geometry
See below:
<?xml version="1.0" encoding="UTF-8"?>84307950_loadstomap.thumb.png.d4c31a069931c7f7af283eaa4c413e5a.png
The pressures applied to the surfaces
<?xml version="1.0" encoding="UTF-8"?>2012590402_mapedload.thumb.png.4905b768a0040579d88b0de02f303c4b.png
The mapped loads after using BC -> Loads on Geometry.
After running a free sizing optimization the result I get for the plies is not completely symmetric (although I constrained my design variables to be symmetric). See below:
<?xml version="1.0" encoding="UTF-8"?>530692030_ply102200onhw_presmooth.thumb.png.2bf668accfbd30339f357944949e270a.png
As you can see, to the edge the ply is definitely not symmetric.
So, what I would like to know is:
Is it possible to, first, mesh half the surfaces and then duplicate half the nodes using the symmetry plane; After this I would like to map the symmetric nodes I created to the existing half surface that was not meshed so I could apply the pressure load to the full surface and then map it to the existing nodes.
The goal is to have a completely symmetric mesh so that maybe Optistruct has an easier time creating symmetric plies.
Thank you very much!
Gonçalo Pimenta
1 - 15 of 151
    Altair Employee
    OP
    Hi goncalop,
    Did you try pattern grouping in the Free Size Panel?. Using this you will get symmetric pattern.
    Yes you can mesh half the geometry and use reflect panel to reflect the mesh created to other half.
    Thank you
    Altair Employee
    OP
    Hi @Premanand Suryavanshi, how are you?
    Thank you for your reply!
    I used pattern grouping - 1 plane symmetry on the design variables but the result was the one you saw above..
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8c210c64d96e1cb667c9c726bb27385e.png
    So, if I mesh the red surface first and then reflect to 'mesh' the blue surface, will the blue surface be associated with the reflected nodes?
    This question because, as mentioned above, I'll need to map the pressure loads to the nodes and I use the surfaces to do this.
    The red surface will map the pressure load to the mesh I created with it but, will the blue surface map the pressure load to the reflected nodes?
    Hope I was clear and you understand what I'm asking.
    Gonçalo Pimenta
    Altair Employee
    OP
    Why don't you try and see.
    Thank you
    Altair Employee
    OP
    Sorry for the redundant question... I've just tried and it does work.. I must have tried it sometime before and done something wrong..
    I'm trying to find a work around for a problem and it's driving me mad.
    Sorry for wasting your time!
    Thank you for taking the time to answer me!
    Gonçalo Pimenta
    Altair Employee
    OP
    goncalop,
    No problem. I'm happy to help you. You can get back with your problem anytime. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Thank you
    Altair Employee
    OP
    goncalop,
    If you are still facing any problem please let us know.
    Thank you
    Altair Employee
    OP
    I don't know what I did in the morning but I probably pressed reflect twice of something like that. I was building a new model with the symmetric mesh and BC - Loads on Geometry doesn't work. Also, if I try to apply the pressure and then chose, elements by geometry, it also doesn't work..
    I first noticed this with the connectors that were acting weird. Then I proceed to test the loads and it definitely doesn't work.. Take a look:
    <?xml version="1.0" encoding="UTF-8"?>224260567_CONNECTORDETAIL2.thumb.png.76f04a5633d7d3122701eba043f5cd26.png
    <?xml version="1.0" encoding="UTF-8"?>1476953886_CONNECTORDETAIL3.thumb.png.9151e0916975bbfa5635ee66908ae26c.png
    <?xml version="1.0" encoding="UTF-8"?>400530206_CONNECTORDETAIL.thumb.png.11a6c5838075b5817e3f14dc6dd50a5c.png
    Although the mesh is symmetric, on the side that was originally meshed, the connectors seem to be more numerous and have a mesh with a smaller square.
    <?xml version="1.0" encoding="UTF-8"?>MESH.thumb.png.ea827dd2a64f33d194d12a9ebc56a4d0.png
    Here, you can see the mesh and the pressure loads applied to the surfaces (the surfaces are hidden). When I map the load, this happens:
    <?xml version="1.0" encoding="UTF-8"?>1745781260_MAPPEDLOAD.thumb.png.235399f235ca0b4a0b79bee65c86143f.png
    The side I originally meshed (left) gets the loads on the elements created from the surface. On the right side, the mapping fails..
    Do you have any idea how to solve this?
    If you need some background on what I'm trying to do, check this post:
    It's a little bit extensive so far but every problem I've faced (and am facing) so far is more or less well detailed there.
    Thank you for your help!
    Gonçalo Pimenta
    Altair Employee
    OP
    Hi goncalop,
    Please can you share your model.
    Please use below FT link to share your model.
    https://ftin.india.altair.com:8443/filedrop/~osKE8Q
    Thank you
    Altair Employee
    OP
    I just sent you the .hm file I was working on.
    If you need anything else, let me know!
    Thank you very much,
    Gonçalo Pimenta
    Altair Employee
    OP
    Hi,
    I got your file. Working on it.
    Thank you
    Altair Employee
    OP
    HI @goncalop
    You can try transformation tool to reflect elements and loads.
    Altair Employee
    OP
    Hi @Prakash Pagadala,
    So I apply the loads before reflecting the elements, this way the elements reflected have the loads applied to them too. Am I right?
    Also, what about the connectors?
    Thanks!
    Gonçalo Pimenta
    Altair Employee
    OP
    HI,
    Yes, you apply or map the loads on Geometry to elements and reflect both elements and loads. But make sure you select transform loads and right direction to reflect.
    Altair Employee
    OP
    Thanks @Prakash Pagadala!
    I will try that this morning.
    Do you have any suggestion regarding the connectors (the problem shown above)?
    Gonçalo Pimenta
    Altair Employee
    OP
    @goncalop
    You can also try reflecting the connectors. Make sure at the end you equivalence nodes.
