Update SPC Location Issue
Hello,
Was trying to update SPC application location in HM but I was just not able to do it. The following images will show what I was trying to do. Perhaps I missed out a step or did something wrong, which I am hoping would be pointed out here.
<?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
Hi,
I wanted to report a possible bug. When updating constraints, if I select loads via 'By Collector' option, the location update option does not show up. <?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
However, if I manually select the load via clicking, the application region option shows up (node option below...but not getting point option which I got earlier once. Very strange behavior).
Hi @Burner2k
That is not a bug. It is not possible to update the locations of multiple SPCs from a single collector.
Check on the 'entity'
Don't check on 'curve'
