Any better mesh strategy to avoid element quality error?
Here is our project:
We wanna do some topology optimization on a feul door component as you can see in attached figure:
We used two surfaces to trim the oringinal solid part into 3 separate components. We wanna keep the blue and yellow unchanged and minize the weight of the red part while still satisfy some strength requirement.
We used tetra element and mesh the component autoly. As you can see, there are some low quality, flat and squeezed elements (white ones in the black circle) near the intersection area between design and undesign space. After I set up everything (Boundary condition, Force, Optimization settings), and click optistruct, the system operator tell me that we failed in element quality check. I think it perhaps has sth to do with the model geometry.
Here is the problem:
Now that we cannot change the model geometry, is there any better mesh strategy to obtain a better mesh to pass the element quality check? (I know that auto mesh is definetly not an idea choice) I tried auto tetra mesh with a smaller element size and it didn't work.
Since I'm a beginner and have to learn everything from the very beginning, can you also provide me some basic tutorial links? (Video tutorial will make life much eaiser lol)
- Because it's the same material, you can merge two solids in order to avoir bad elements
- Because it's not the same material and because of tangential surface, there're ALWAYS some bad elements at this zone. You can decrease element size but that does not remove all bad elements.
No, I see ... nothing
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Really? I can see the graph in my browser... anything goes wrong?
I don't SEE either /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Maybe you can use QI optimize mesh with all your quality parameters checked.
You can also bypass the quality issue using ControlCards>>PARAM>>elemcheck>>NO
I don't SEE either
Oh, what do you mean by can see nothing? You mean can't see the figure?
Sorry....What is QI optimize mesh? Any tutorial so that I can learn?
I re-attached the figure, could you pls look into the problem again?
Thank you!
I re-attached the figure, could you please look into the problem again?
Thank you!
Ha, thanks! It's a 2D tutorial, but we can still play the same trick on 3D elements right?
Share your model and show us directly where's your problem?
No problem~ after I can import that stp file into the student version on my laptop
Here is my model (it's a optistrut project running into mesh problem)
Here're my remarks:
Here're my remarks:
Yes, the blue comp (pin) and the red comp (hinge) are the same mat, but we only wanna do topology optimization on the hinge. I think that if we merge these two components, we'll unable to do optimization separately on the hinge, am I correct?
For the second tip, now that bad elements always exist, does this mean we can never carry out the topo opt since we'll always fail the element quality check? How can we solve this problem? Skip the quality check, change the model geometry, or other ways?
Thank you!
One way is merge the components as @Q.Nguyen-Dai suggested and move the elements which falls under blue part (approximately) in to a different component and make it as a non-design space for optimization. The other way is extract faces on the hinge (where the blue part and hinge meets) and mesh in to two components.
You can Bypass the element quality check. Use the control card CHECKEL>>NO
Goto Analysis>> Control Cards>>PARAM>>CHECKEL>>NO
