🎉Community Raffle - Win $25
Join and Win
Hello, I have downloaded the Altair_lic.dat file, as well as set the Altair_license_path variable in my windows settings, and the program license still won't activate in Inspire. Can you please
User: "sandeep  s  kudapa"
Altair Community Member
Updated by sandeep s kudapa
1 - 7 of 71
    User: "SLarrazabal"
    Altair Employee
    Updated by SLarrazabal
    Hello Sandeep,
    the problem could have different causes. In order to get more information about what is not validating the license you need to click on the License Log button, there you will get more information about the issue.
    I'm thinking that you could see errors like:
    - HostID does not match license: If you see this, you need to double check and choose the correct HostID on your machine to get your license file generated.
    - Unable to read license: The environment variable might not be pointing to the righ license file. Make sure the valu is the full directory with file name and extension.
    - Feature not found: This could have different reasons, make sure that your license is compatible with the application you are trying to use.
    If you can share the details in the license error log, I can help you identify the issue.
    OP
    Hello Sandeep,
    [11/02/21 21:55:49] System Error: No Auth Token in HHWU Config
    [11/02/21 21:55:20] [Async] Trying activate features...
    [11/02/21 21:55:20] Trying to activate...
    [11/02/21 21:55:20] Deactivating features...
    [11/02/21 21:55:20] Activating...
    [11/02/21 21:55:20] Activating required features
    [11/02/21 21:55:23] System Error during checking out: Altair License Manager: License error
    Feature(s): GlobalZoneAP, HyperWorks, HWInspire
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    [LOCAL] E:\New folder\security\altair_lic.dat - (Err: 9) Feature not found
    License Path: E:/New folder/Inspire2021.2.1/../security/altair_lic.dat;E:\New folder\security\altair_lic.dat
    Feature(s): GlobalZoneAP, HyperWorksEDU
    Error Code: 9
    Error Description:
    Feature not found
    Feature: HyperWorksEDU
    Error Code: 9
    Error Description:
    [11/02/21 21:55:23] [Async] Failed to activate
    [11/02/21 21:55:49] Releasing features...
    [11/02/21 21:55:49] Invalid state for releasing
    [11/02/21 21:55:49] Failed to release
    [11/02/21 21:55:49] Trying activate features...
    [11/02/21 21:55:49] Trying to activate...
    [11/02/21 21:55:49] Deactivating features...
    [11/02/21 21:55:49] Activating...
    [11/02/21 21:55:49] Activating required features
    [11/02/21 21:55:50] System Error during checking out: Altair License Manager: License error
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    License Path: E:/New folder/security/altair_lic.dat;E:/New folder/Inspire2021.2.1/../security/altair_lic.dat;E:\New folder\security\altair_lic.dat
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    [11/02/21 21:55:50] Failed to activate
    This is my license log
    User: "SLarrazabal"
    Altair Employee
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Sandeep,
    in the License setup window, Local file, please click in the folder and navigate to the altair_lic.dat license file on your machine, then click on Activate. You should be able to activate the license this way, if not, please share the error log again.
    OP
    Sandeep,
    I did soo, but still the license didn't activate. attaching the log data
    [11/02/21 23:29:52] System Error: No Auth Token in HHWU Config
    [11/02/21 23:28:49] [Async] Trying activate features...
    [11/02/21 23:28:49] Trying to activate...
    [11/02/21 23:28:49] Deactivating features...
    [11/02/21 23:28:49] Activating...
    [11/02/21 23:28:49] Activating required features
    [11/02/21 23:28:55] System Error during checking out: Altair License Manager: License error
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    [11/02/21 23:28:55] [Async] Failed to activate
    [11/02/21 23:29:52] Releasing features...
    [11/02/21 23:29:52] Invalid state for releasing
    [11/02/21 23:29:52] Failed to release
    [11/02/21 23:29:52] Trying activate features...
    [11/02/21 23:29:52] Trying to activate...
    [11/02/21 23:29:52] Deactivating features...
    [11/02/21 23:29:52] Activating...
    [11/02/21 23:29:52] Activating required features
    [11/02/21 23:29:52] System Error during checking out: Altair License Manager: License error
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    [11/02/21 23:29:52] Failed to activate
    User: "SLarrazabal"
    Altair Employee
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Feature: Inspire
    Error Code: 9
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Sandeep,
    I would recommend you to uninstall the software and then reinstall it in a directory with no blank spaces. Then download a new copy of your license file and place it in the <install_dir>\security. There should be a security folder, you don't need to create one. If you can, I encourage you to select the default installation directory which is C:\Program Files\Altair.
    Once the license file is placed, change the value on your ALTAIR_LICENSE_PATH environment variable and point to the correct license file.
    If you are still experiencing issues, please creat a Case on the Contact Support section.
    User: "Marcel Stockmann"
    Updated by Marcel Stockmann
    i have the same problem...
    [01/24/22 22:21:57] [Async] Trying activate features...
    [01/24/22 22:21:57] Trying to activate...
    [01/24/22 22:21:57] Deactivating features...
    [01/24/22 22:21:57] Activating...
    [01/24/22 22:21:57] Activating required features
    [01/24/22 22:21:58] System Error during checking out: Altair License Manager: License error
    Feature(s): GlobalZoneEU, HyperWorks, HWInspireCastGUI
    Error Code: 9
    Error Description:
    Feature not found
    Feature: InspireCastGUI
    Error Code: 9
    Error Description:
    [LOCAL] C:\Program Files\Altair\2021.2\security\altair_lic.dat - (Err: 9) Feature not found
    License Path: C:/Program Files/Altair/2021.2/security/altair_lic.dat;C:/Program Files/Altair/2021.2/InspireCast2021.2/../security/altair_lic.dat;C:/Program Files/Altair/2021.2/InspireCast2021.2/security/altair_lic.dat;C:\Program Files\Altair\2021.2\security\altair_lic.dat
    Altair Hosted HyperWorks Units: License error
    Error Code: -40
    Error Description:
    [LicID -1] (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses
    [01/24/22 22:21:59] System Error during checking out: Altair License Manager: License error
    Feature(s): GlobalZoneEU, HyperWorksEDU
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Error Code: -40
    Error Description:
    [01/24/22 22:21:59] [Async] Failed to activate
    User: "SLarrazabal"
    Altair Employee
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Error Code: -40
    Error Description:
    Error Code: 9
    Error Description:
    Feature not found
    Error Code: 9
    Error Description:
    Error Code: -40
    Error Description:
    Hello Marcel,
    according to the error message the application is detecting that you are located in a European Time Zone and the license is not able to provide the feature neede for that.
    If you think this is an error and you should be able to use the license from your current location, I would recommend you to contact your account manager and inform him/her about this situation.
